IFS ERP INTEGRATION CAPABILITIES
Seamlessly Integrate, Orchestrate & Enhance Your IFS System. Connect All Your Existing Applications or Build your new Apps by simply drawing them in Novacura Flow – user-friendly low-code platform.
Novacura is an official IFS Channel Partner of the Year
Novacura Flow is a robust integration platform for IFS Cloud / IFS Applications designed to simplify and enhance your system connectivity. With a toolkit of over 50 connectors, it is capable of seamlessly linking with popular business systems, cloud platforms, and services, providing a streamlined integration process across multiple systems. Furthermore, external systems can easily call upon any Novacura Flow application as a web service, allowing Novacura Flow to function efficiently as a service bus. This ensures not just integration but also fluent communication between your applications and services, fortifying the efficiency and reliability of your business processes.
IFS Integration Platform
ERP capabilities: Key Features:
SPECIALIZED IFS CONNECTORS
Novacura Flow is equipped with dedicated IFS connectors. No matter which IFS version your organization uses (IFS Cloud or older IFS Applications), you can easily connect Novacura Flow to it using pre-defined connectors that hide all the technical complexity behind an easily configurable user interface.
50+ CONNECTORS TO EXTERNAL SYSTEMS
Novacura Flow is armed with over 50 connectors to the most popular business systems, cloud platforms, and services, ensuring smooth integration.
EASY CREATION OF INTEGRATION SERVICES
You can create integration services in a visual way – instead of writing scripts, you can build them by drawing diagrams. You can combine multiple data exchange steps into complex processes, integrate various external systems within a single integration flow, and create advanced integration services in a way that is easy to understand and maintain.
Create IFS integration services in a visual way, image by Novacura
DEDICATED TO GROW ERP SYSTEMS CAPABILITIES
Novacura Flow Integration Engine is not just another Integration Platform. It is dedicated to cooperating with ERP systems. This platform has been by design prepared to expand IFS systems.
Novacura Flow “surrounds” the IFS system and constantly operates on ERP objects using authorized API methods (OData API for IFS Cloud, or PL/SQL API for IFS Applications).
Novacura Flow is designed to expand IFS systems
MAINTAINED & CERTIFIED
New versions of IFS systems constantly bring changes to their APIs. Sometimes, when a new revolutionary version of an ERP comes to life, the entire connectivity technology and protocols are changed (i.e. the OData interface that was introduced with IFS Cloud, or the new REST API for SAP products). The compatibility, as well as ERP configuration, is crucial to keeping our "deep ERP integration", therefore Novacura Flow Connectors are constantly maintained by our R&D team.
Novacura Flow Connectors are constatly maintained and support all IFS modules
READY TO INTEGRATE EMERGING TECHNOLOGIES
Novacura Flow can be used as a bridge to the latest technologies for the ERP system. It offers connectivity to generic cloud services like Artificial intelligence (AI), Document recognitionComputer vision, or Augmented reality. It also supports physical equipment integration, which is important for specific industries. It can be connected to gauges, machines, robots or vehicles.
Enjoy low-code benefits with Novacura Flow technology bridge for ERP, image by Novacura
READY TO INTEGRATE MULTIPLE ERPS
Novacura Flow can perfectly function as an integration platform and synchronize data between different business systems that exist in your organization. This basic situation typically arises in capital groups, where separate subsidiaries (operating in different regions) use different business systems, adapted to their country, scale and profile. Novacura Flow can integrate different types of ERP (i.e. Infor M3 and IBM Maximo), different versions of the same ERP (i.e. IFS Cloud and IFS Applications 9) or just 2 separate installations of the same IFS.
Novacura Flow is ready to integrate multiple ERPs
INTEGRATION SERVICES:
The technical ability to connect to IFS (via dedicated Connectors) is not enough to build real ERP integrations. To do that, the application developer must know all the necessary API objects (methods, entry points, projections, etc.) belonging to the large API consisting of 1000+ methods, projections, and endpoints. Moreover, the developer must know which methods and what sequence to use to complete complex tasks in the ERP. But our customers are not alone here – Novacura (as an IFS Channel partner) has a lot of knowledge about these APIs and is ready to help customers build the most complex ERP applications.
#Contact
Contact our expert:
Please fill out the form
Aksel Jarlbäck
Solution Expert
