If you work in manufacturing, you’re probably familiar with the challenge of avoiding defective products. A defect as small as a missing or unidentifiable barcode can result in downtime and disappointed customers.
To limit the number of defective products, manufacturing companies struggle to manage these visual quality inspections. This article will introduce how to improve these inspections through computer vision for quality control – a field of artificial intelligence that trains computers to interpret and understand the visual world.
Problem - the cost of quality inspections
Every company in manufacturing has the challenge of reducing the number of defective products. Quality inspection in manufacturing is a must; otherwise, faulty products will appear one way or another.
Defective products can cause damage and result in unexpected expenses, leading to customer complaints, downtime, labor costs, and scrapped products.
Therefore, dedicated people are often used as the quality checkpoint, visually looking at the production line – which costs time and money.
The quality check is critical, but manual visual quality inspection slows down the production phase since you must ensure the inspector can keep up with the production line.
Is it worth it? Well, it’s necessary to ensure high-quality products – even though it’s a costly expense for the company. In some cases, where risk is high, the cost of letting defective products slip through is considered worse. E.g., delivering faulty products to a client/customer could result in lost contracts/agreements. Therefore, it’s essential to avoid these scenarios and reduce errors, even if that often means having a lot of resources in place and a slower production phase.
A well-designed systematic quality inspection will have a positive effect on:
  • Downtime
  • Defective product
  • Loss of revenue
  • Lost customers
  • Wasted time
  • Wasted resources & man-hours
  • Wasted money
  • Decreased OEE / utilization
  • And more..
In most cases, posting a person on the production line at each point of quality inspection is often too expensive – so let’s talk about alternatives using new technologies and solutions like computer vision.
Solution - reducing defects and human errors by using computer vision analysis
The solution is to install relatively inexpensive cameras in locations where you typically place, or would like to place, a person for visual inspections. By using digital images and video from these cameras, we can train computer vision models to perform analysis. These models enable the cameras to accurately identify and classify objects during production line inspections. An edge computing device processes each frame, performs the analysis, and ultimately outputs the result that the model was trained to generate.
Computer vision analysis helps reduce human errors and defects, image by Novacura
With these frames from a video, the model can be trained within a few hours to identify defects in real-time wherever you have repetitive quality inspections. We can then use this data to react to what the camera “sees.”
Example 1: Best by dates on packaging
Implementing object detection and quality control with computer vision on a packaging production line to detect valid printed Best By dates on packaging. This will allow the detection of misprinted, invalid, or missing Best By codes to be removed from production before being boxed and sent distributed to customers.
Example 2: Identifying cracks in metal pieces
We have a piece of metal running down the production line and want to check for cracks. This is where usually a person is standing, looking at it to identify the cracks. In this computer vision model, we can train artificial intelligence (AI) to decide for us – we can take pictures and determine which one shows a crack or not. Better yet, when cracks are undetectable to the naked eye, specialized cameras can be put in place to enhance this process.
Example 3: Detecting Missing Components in Assembly Lines
In an electronics assembly line, small components like resistors, capacitors, or screws can sometimes be omitted during manufacturing. A computer vision model can be trained to detect missing components in real-time by analyzing images of assembled boards or products. This ensures that faulty units are flagged and removed from the production line before reaching the testing phase, reducing downstream costs and improving efficiency.
Example 4: Ensuring Labeling Accuracy on Bottles or Containers
In industries like food and beverage or pharmaceuticals, accurate labeling is crucial for compliance and customer trust. Computer vision can inspect labels on bottles or containers to ensure they are correctly applied, legible, and match the product inside. This includes verifying barcodes, logos, and text alignment. For instance, detecting misaligned or partially printed labels can prevent products with improper packaging from being shipped to customers.
Results and benefits
When implementing computer vision analysis, you can quickly identify results that enhance quality assurance:
  • Improved product defect detection
  • Reduced waste
  • Reduced lost time
  • Increased customer satisfaction
Compared to a manual inspection by a dedicated team member, computer vision can archive 95-99% confidence in its detection while costing less and removing the human error factor in a single process, scaled up with multiple cameras throughout a process – This technology can improve quality and reduce waste.
What are the most impressive features of this solution?
  1. Realtime Object detection
  2. Instantaneous post-processing of detected results
  3. Stationary and Moving Object detection
  4. Continuous prediction model improvement
  5. Multiple levels of Inferencing
It’s impressive how many use cases it could be applied to – all we do is to train the model to look at something, what that something is up to us to define. Which means there are never-ending use-cases. Not limited to quality inspections but limited by the imagination.
Paul Phillips
Novacura, Product Manager
Example of computer vision Real-time Product Recognition and Counting
What is unique with the solution from Novacura?
Customers worldwide are using different solutions for machine learning, virtual workstations, high-performance computing and IoT services. The unique thing with Novacura is that we don’t only provide AI solutions. We also connect the downstream processes. With Novacura FLOW we can connect to ERP, HMI, WMS, PLM, SCADA etc.
Other suppliers might be able to give you the data – but it’s what you do with the data that counts (...)
Paul Phillips
To summarize
By using an advanced inspection system with computer vision for real-time monitoring and identification of defective items on the production line, companies can reduce costs, increase efficiency and increase customer satisfaction.
There will always be best-of-breed solutions, but with Novacura you will get the artificial intelligence (AI) solution and a platform that you can do more with, such as mobile applications. The knowledge we have in Novacura in combination with these solutions is, what we would call, an unbeatable combination.
To learn more about using AI computer vision in your business, watch our on-demand webinar: Using AI to accelerate efficiency gains in Manufacturing and Engineering. We’ll discuss some of the challenges businesses face and provide real-life examples of how Manufacturers use AI computer vision to optimize efficiency.
